Hello Guest it is November 01, 2026, 10:13:40 AM
Author Topic: Sanity check please - LC not posting  (Read 10145 times)
Offline Mattw
  •  41 41
« on: December 31, 2009, 09:53:31 PM »
Could one of you capable folks load this dxf and see if LC will post code.  I can't seem to get anything to post.  I thought it might be because I don't have the Pro version of LC, so I generated this simple zigzag.  I tried all available dxf formats, but got the same results from all.  I do have the mach license.
Maybe re-install LC?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Sanity check please - LC not posting
« Reply #1 on: January 01, 2010, 01:20:41 AM »
Hi, Mattw
Loads and posts just fine hear.
Chip
« Reply #2 on: January 01, 2010, 08:38:15 AM »
Did you take a look at the LC manual on posting?
Offline Mattw
  •  41 41
« Reply #3 on: January 01, 2010, 10:55:49 PM »
Thanks for checking.
Whatever it was, re-installing LC fixed it.  It'll post every time now.
If it helps anyone with debug, what I was seeing down in the "Project" window was the text saying the g-code was created, but I was not getting the pop-up window saying the code was created, with the location and file name.
All is good now.
p.s. Rich, I did not find anything in the manual relating to this problem.  I even did a search for every instance of "post" in the manual in case it was slipped in somewhere else.  Did I miss something?  Are we talking about "LAZYCAM_MANUAL_REV_1.PFD", or is there another manual out there?
Thanks again for the help!
« Last Edit: January 01, 2010, 11:01:50 PM by Mattw »
« Reply #4 on: January 02, 2010, 08:22:48 AM »
Mattw,
I have made a note to myself to add some more info on posting. Whenever that may be!
Good going on watching the project info as it gives you a glue as what LC is doing.
There are times that LC will not give you a gcode file but said  the gcode was created. That is usualy a clue to me that something is wrong with my tool parameters as they apply to a command.
In that light, that would not have helped if a bad installation was done, so at least you have it working.
If you have a problem, just post, and yes include the DXF.
Known problems / bugs are listed in the back of the manual. There may be more, but that's what i found when writing the manual and reading all the replies ever made about LC.
