Hello Guest it is November 10, 2026, 01:56:26 AM
Author Topic: Facing Code  (Read 6648 times)
Facing Code
« on: December 31, 2009, 12:37:30 PM »
I want to add a facing "LATHE" routine to a screenset
This will be on a button using some user dros
If anyone has some code already that would be great or example G code that works from a button so i can get the gist of it
I have tried a search but couldn't find anything
melee
Re: Facing Code
« Reply #1 on: January 02, 2010, 12:06:41 PM »
Hi Phil
You don't seem to have any takers.
I am sure I can provide you with some code, if you can say exactly what you want to do.
If you are looking for something which will face off a billet flush by x amount, the code is quite simple, the only other variables really being billet diameter and depth of each cut.
Let me know what you want, send a PM if you like
regards
Melee
« Last Edit: January 07, 2010, 03:32:35 AM by melee »
