Hello Guest it is November 13, 2026, 10:37:38 AM
Author Topic: PWM Questions  (Read 22329 times)
PWM Questions
« on: December 31, 2009, 10:59:23 AM »
I'm trying to figure out some specifics about the PWM output.  No luck on the forum, so maybe this could be a reference for others.
Questions:
1.  Is there a set pulse rate for the PWM?  If so, what is it?  Or, does it change if you change the Kernel Speed?
2.  If I set Pulley #1 to 0-100, does that mean that I can vary the PWM by using S0 - S100 in a G-Code line?
3.  If I set the PWM Base Frequency at 500, that is a divisor into the the Kernel Speed.  So, if Kernel Speed is 25000, the I have 25000 / 500 = 50 possible speeds.  What are the ins / outs of setting the Frequency higher or lower.  That is, if I set this at 10 do I get smoother output?  Why would I set this higher or lower?
My guesses at the moment are:  1.  No clue  2. Sounds right but I don't think it actually works that way  3.  I think too small will make it jumpy
Re: PWM Questions
« Reply #1 on: December 31, 2009, 11:08:28 AM »
1) PWM base frequency is set in Config->Ports&Pins->SpindleSetup.  The PWM output gets updated at the kernel rate.
2) Yes,
3) There is nothing to be gained by setting a high base frequency for the PWM.  5-10Hz is pretty typical.
Re: PWM Questions
« Reply #2 on: December 31, 2009, 06:10:48 PM »
Questions:
1. The base frequency and the kernel speed determine the resolution of the PWM output. The resolution is the number of PWM steps you have between 0 rpm and your maximum speed.
The resolution is determined by kernel Speed/PWM base frequency. So;
For Kernel speed of say 25KHz and a PWM base frequency of say 10Hz you end up with,
25000/10 = 2500 steps. If you have a PWM base frequency of say 100Hz then you get;
25000/100 = 250 steps.
If you have a spindle maximum speed of say 10,000rpm, then the resolution will be
4 rpm per step for the 1st example, 10000/2500 = 4. for the 2nd it will be 40rpm per step.
10000/250 = 40.
The higher you set the PWM frequency, the lower the resolution you can achieve. That said, an open loop speed control would be hard pressed to use a resolution of 4 rpm.
From a practical point of view I recommend a base frequency of 50hz. I provides good response and seems to be less affected by electrical noise.
2. The PWM output is a mark/space waveform calculated as a % of the maximum spindle speed. So if you set the max pulley speed to 1000, then the PWM output ratio is calculated as;  PWM = Speed/Max Pulley Speed  * 100. So if you set speed to 300rpm by S300  the PWM ratio will be
300/1000 *100 = 30%
3. I have found that a higher base PWM frequency, gives better noise protection.
    If you have a low base frequency, you need more filtering to keep the output ripple down.
Cheers,
Peter.
Homann Designs
http://www.homanndesigns.com
Re: PWM Questions
« Reply #3 on: December 22, 2016, 11:29:50 AM »
I have a different problem. My PWM output is getting affected by mouse movement and screen selection. If on the MDI screen and I move the mouse i get near perfect square wave output at the programed rate. I stop moving the mouse and the output becomes very jerky. Also if I select the jog screen the jerkiness is more pronounced, still affected by mouse movement but square wave output is not as good as MDI.
I have tried different frequencies settings as recommended but all get affected in a similar manner. I also tried a different mouse USB and PS2.
