Hello Guest it is November 13, 2026, 04:48:29 PM
Author Topic: Reset button  (Read 11570 times)
Reset button
« on: December 30, 2009, 12:24:20 PM »
Hi. I want to make Reset button for mach3 on my control panel, but I don't know how. Maybe anyone can help?
Re: Reset button
« Reply #1 on: December 30, 2009, 01:16:09 PM »
Just connect a momentary switch to an input on your port. Go into Ports and Pins, Inputs and assign the port and pin number of the button to one of the OEM Triggers. Next go to Config menu then System HotKeys and in the box at the side of the OEM Trigger your switch is connect through you put the OEM code for RESET which I think is 1001 but will check and confirm in a few mins.
Thats it all done :)
Edit
 Reset is OEM 1021.
« Last Edit: December 30, 2009, 01:18:45 PM by Hood »
Re: Reset button
« Reply #2 on: December 31, 2009, 04:23:52 AM »
Thanks, that was all what I needed :)
