Hello Guest it is November 13, 2026, 05:55:53 PM
Author Topic: Sneek Peek, at the screen set and functions for the new PoKeys Plugin...  (Read 11312 times)
Hello,
    Here is a screen shot of the new Matrix Keyboard upto 8x16, and Matrix LED two 8x8 diagnostic/testing page.
Some major Firmware changes where made in the PoKeys it self to add the above, this forced some major changes in
the plugin as well.
1).   If you use a LCD you will have to move it to the Secondary LCD pins and configure it that way in the PoKeys software.
since if you where to use a second Matrix LED it will conflict with the old primary LCD pins.
2).  The way the 32 bit encoders are called has been changed some, (in the plugin) to help smooth them out a little better.
3).  Analog inputs, have a small dead band put in them so to limit dithering (about a 4 bit range).
4). He Pinouts on the: Plug and Play, 4/6 and PoPendants have been moved.
The new plugin is currently in BETA testing, so when the "bugs" are found and squeeshed it will be released, probably vs. 9.5
here is a screen shot of the Matrix page:
Scott
