Hello Guest it is November 13, 2026, 09:04:26 PM
Author Topic: Machine Zero  (Read 15744 times)
Machine Zero
« on: December 24, 2009, 08:26:55 PM »
I have a problem setting up a program from time to time. I import gcode into mach3 from mastercam. The gcode's origin becomes the machine zero origin and not the G54 origin as intended, whatever I do, I can't change it. Fiddling with the "Program #" in mastercam has fixed the problem before but it is fairly sporadic. .  I tried zeroing all the work offsets, G55+ to a new zero but it didn't help. . . I think there is something I am missing. Thanks!
Re: Machine Zero
« Reply #1 on: December 24, 2009, 08:40:18 PM »
Where is the origin in reference to your part ?
Home the machine, select WORK coordinates, jog to the ORIGIN of the part, zero the x and y axis's and BINGO !
Do a Regen and you should be fine.
Re: Machine Zero
« Reply #2 on: December 24, 2009, 09:52:26 PM »
I uncheck the "Machine Coord's" so the red backlight is off to go to WORK coordinates.
If that is a true statement then I have done what you say to no avail.
Am I going to work coordinates correctly?
Re: Machine Zero
« Reply #3 on: December 24, 2009, 10:11:46 PM »
Yes...thats correct.
Can you post the file ?
Maybe the DXF ?
Re: Machine Zero
« Reply #4 on: December 24, 2009, 10:17:44 PM »
Have you watched this video ?
It explains in great detail.
Re: Machine Zero
« Reply #5 on: December 29, 2009, 06:03:31 AM »
Overloaded,
Please provide link to the videos you have posted!
Re: Machine Zero
« Reply #6 on: December 29, 2009, 06:37:33 AM »
You will find the videos on the ftp
ftp://anonymous@machsupport.com/Videos/
Re: Machine Zero
« Reply #7 on: December 29, 2009, 06:46:22 AM »
At the top of this page under Support.
