Hello Guest it is November 11, 2026, 11:15:05 PM
Author Topic: Intermittent error with Mach3  (Read 8579 times)
« on: December 24, 2009, 01:07:37 AM »
Hi, I have been having intermittent errors when I run GCode files.  Right at the start where Mach is given an M3 command, I sometimes get a popup that says Error in Line (Line number) - Unspecified Failure and the program stops.  If I then hit cycle start again the program continues, but does not start the spindle. It doesn't do it all the time, but when it does it I have to restart Mach3, then the problem usually goes away.  Has anyone else had this problem?
I am using version R2.61 of Mach3.
John
« Last Edit: January 08, 2010, 10:49:53 AM by Roadkill_321 »
Re: Intermittent error with Mach3
« Reply #1 on: January 07, 2010, 12:34:13 PM »
I have since figured out that the error occurs not when the program sends an M3, but when it sends a G20.
Mach then says "Error in Line 2 - Unspecified failure", Line 2 being where the G20 is.
It is very annoying  >:( and I would like to resolve this if I can.  Any suggestions?
Thanks John
« Last Edit: January 08, 2010, 10:48:39 AM by Roadkill_321 »
