Hello Guest it is November 12, 2026, 12:41:54 AM
Author Topic: Encrypt Screen set  (Read 26110 times)
Encrypt Screen set
« on: December 23, 2009, 05:12:07 AM »
Would this be possible so that only the originator could edit the screen-set ?
Phil
Re: Encrypt Screen set
« Reply #1 on: December 23, 2009, 10:28:14 AM »
Hi Phil,
as far as I know, can you only put a password on your setfile. The passwords are supplied by Artsoft.
Klaus
« Last Edit: December 23, 2009, 10:30:38 AM by Klaus1311 »
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: December 23, 2009, 10:57:00 AM »
Don't get scared Phil,
I just tried Klaus's screen designer and at the rate i am going you have a least a 6 months before i get dangerous.  :D
Maybe longer.....  ;D
« Reply #3 on: December 23, 2009, 10:59:30 PM »
No not worried in the least, i have an application in mind for the future, something that no one has done before.
Don't ask my lips are sealed.
Phil
