Hello Guest it is November 13, 2026, 08:06:14 PM
Author Topic: COMPLEX THREADING WIZARD  (Read 11074 times)
« on: December 22, 2009, 07:32:55 PM »
Here is a link to a threading wizard which i didn't know existed.
http://www.machsupport.com/forum/index.php?action=dlattach;topic=13434.0;attach=18904
I took a few moments and found a few things that you should be aware of .
1. In the thread selection, if you pick a ISO MET 60, the calculated depth is incorrect for a sharp V tool.
IE; pitch=.050 ,external thread, if tip radius is 0.0000, the depth should be ( 0.866 x  P= 0.050 x .866=.0433).
There is no definiton for a "Standard full profile" and the tip radius it provides is .0072.  The end value of the X distance for the thread uses ths value and will be incorrect. Just a heads up.
I will note that the "Calculator " does the depth / x end diameter correctly.
If you input the "end" value correctly the g code generated uses that value.
2.Not sure if TEST ( True / False ) is working correctly. I figured it woudld generate a g32 or g76 type of gcode posting.
Re: COMPLEX THREADING WIZARD
« Reply #1 on: December 22, 2009, 08:41:36 PM »
I was in hopes that the complex wizard would go away :) it was far to complex  to be useful ;(
But if you would like to fix it... You have my permission to do anything you like :)
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: December 22, 2009, 08:43:31 PM »
Oh good grief Brian, I thought it was the best thing since sliced bread..... ;)
not to complex.....heck, fix it and i will do a write up!  >:D
« Last Edit: December 22, 2009, 08:47:44 PM by RICH »
