Hello Guest it is November 13, 2026, 08:09:01 PM
Author Topic: Bridgeport mill and back gear spindle reversal  (Read 30488 times)
« on: December 21, 2009, 05:54:01 PM »
I have a Bridgeport milling machine and how can I tell Mach software to invert the spindle direction in Back gear using switch hooked to the lever
Adam
Re: Bridgeport mill and back gear spindle reversal
« Reply #1 on: December 21, 2009, 05:56:51 PM »
I am not sure if checking reversed in the pulley setup page will do that or not, if not then you will need custom M3 and M4 macros.
« Reply #2 on: December 21, 2009, 06:09:56 PM »
Do the Macros run with in the cw cww button or does the macro run from the m3 m4 code from a program
Adam
« Reply #3 on: December 21, 2009, 06:26:34 PM »
To be honest I am not sure, dont use the button myself as I have external buttons. Will see if I can test it out, just have to think of a way LOl
« Reply #4 on: December 21, 2009, 06:55:30 PM »
Looks like the Spindle CW button ignores the M3 macro and does its own thing, nothing stopping you from putting VB buttons on the screen however. Something like
If GetInput (1) Then
Code ("M3")
Else
Code (M4")
End If
Should work for you, the above would be looking at input 1 for your lever switch, if it was seen then it would do a M3 and if it wasnt it would do M4. You would also need another button to do the M5. In fact you could probably integrate it into the same button by looking at the Spindle on LED and doing the M5 if it was on.
« Reply #5 on: December 21, 2009, 07:40:03 PM »
I did notice in the spindle pulley set up i can set  pulley 1 for high gear and set up pulley 2 for low gear with reversed box checked but I have to set the pulley number manually
Adam
« Reply #6 on: December 21, 2009, 07:41:42 PM »
You can do it from code if you look at the thread that Overloaded has just posted.  http://www.machsupport.com/forum/index.php/topic,13484.0.html
« Reply #7 on: December 21, 2009, 07:47:49 PM »
btw...according to TFM the above is absolutely correct. The REVERSED checkbox is there for this very purpose.
« Reply #8 on: December 21, 2009, 07:50:01 PM »
One day I am going to have to RTFM  then I wont have to keep saying "I am not sure...." or "I think...... "  ;D
« Reply #9 on: December 21, 2009, 08:00:06 PM »
does a spindle speed call automatically switch pulley # base on set values in the spindle set up
Adam
