Hello Guest it is November 13, 2026, 07:58:50 PM
Author Topic: Newbie and having teething probs  (Read 54652 times)
Offline br22
  •  19 19
« on: December 21, 2009, 02:26:29 PM »
Hi guys
I have been fascinated by cnc machinery for a long time and now that they are somewhat affordable I intend to build myself one which will handle a 8 by 4 sheet of plywood.
But before running I want to walk a while so I got myself a small kit so that I can work on it in the warm spare bedroom rather than in a draughty workshop.
It is from buildyourcnc.com I got it from a guy who got  it and then tired of it.
My intention is to build it up and use it to cut the parts for my bigger one.
I have put it all together and yesterday I did the electrics and hooked it up to a PC with mach3 installed.
As soon as I plugged it in the motors "tensed" and the light came on in the control board and everything seemed ok, except that nothing moves.
I believe that I have configured mach3 properly and I have triple checked the wiring.
I installed a port monitor which tells me that the port is active when I use the scroll buttons.
I checked some of the pins with a volt meter but they show 5 volts whether red or green on the monitor.
I hope someone can help me with this as this is my first experience of trying to control something by PC
br22
Re: Newbie and having teething probs
« Reply #1 on: December 21, 2009, 02:33:31 PM »
The installation video should get you up and running.
http://www.machsupport.com/videos/
Offline br22
  •  19 19
« Reply #2 on: December 21, 2009, 02:51:22 PM »
I have watched those videos over and over yesterday and this evening.
I am thinking that there is probably something so simple its not even in the videos anyone (except me) probably knows .
br22
« Reply #3 on: December 21, 2009, 03:00:04 PM »
Have you made sure you have the correct port address?
Have you run the Drive Test to see what the pulse is like?
Offline br22
  •  19 19
« Reply #4 on: December 21, 2009, 03:43:25 PM »
Yes
correct port address and the drive test says excellent
br22
« Reply #5 on: December 21, 2009, 03:46:04 PM »
Do the drives require the enable pins?
Do all the step and dir pins have port 1 assigned to them?
« Reply #6 on: December 21, 2009, 03:47:11 PM »
Can you attach your xml please, if using the standard profile it is called Mach3Mill.xml and its in the main Mach3 folder, you will need to rename to attach to a post.
Offline comet
  •  338 338
« Reply #7 on: December 21, 2009, 04:07:33 PM »
have you checked the port is outputting a pulse? a quick way is to put a small speaker across the axis
step pin and earth(or +5v) and see if it buzzes when you jog that axis
Offline br22
  •  19 19
« Reply #8 on: December 21, 2009, 04:36:46 PM »
Yes Port 1 is assigned to all three axis step & Dir
I don't understand about the drives enable pins
br22
« Reply #9 on: December 21, 2009, 04:43:14 PM »
Some drives require a signal to enable them. Do you have a link to the documents for your hardware?
