Hello Guest it is October 22, 2026, 04:54:56 PM
Author Topic: cutting everything in reverse  (Read 8105 times)
« on: December 20, 2009, 08:06:06 PM »
 Hi
I am having trouble when I try to make name plates everything is witten backwards and up side down such as when i try to engrave Aaron , I get noraA, could someone tell me the settings to correct this and where to change these settings, I am kinda new to all this type of CNC
thanks for any help
Aaron ???
Re: cutting everything in reverse
« Reply #1 on: December 20, 2009, 08:40:05 PM »
Aaron, sounds to me like you may have you motors reversed or your scaleing set to -1. This can be changed in Config, homeing and limits or in the scaleing dros beside the dros on the run screen. You need to searh this forum or the web for the three finger rule or right hand rule. See this one too, it will help.
http://www.machsupport.com/forum/index.php/topic,2560.msg15378.html#msg15378
