Hello Guest it is November 13, 2026, 05:55:06 PM
Author Topic: Help with Pokeys and Reset Feed Rate  (Read 13367 times)
« on: December 18, 2009, 11:56:30 AM »
Finally after much reading and trial and error I have got the pot working in Pokeys for FRO.
I want a separate switch on Pokeys to be able to lock the FRO to 100%.
I have got the brain working for this partially in that it stops input from the pot but it does not reset the FRO to 100%
To simplify things if I can get a switch to work to reset the FRO to 100% and keep it there then I can get this working.
I have connected an on/off switch to pin 5 on Pokeys and it is working fine. I have assigned OEM Trigger #1 to port 10 pin 5.
I have created a brain that goes like this
OEMTRIGGER #1 - No-Operation Pass Signal  - terminating to Button Press OEM1014 Reset FRO
This does work if you press the button attached to Pokeys but it does not hold the state. While the button is on you can adjust the feed rate and then it requires you to turn off the pokey button and then back on again to reset it to 100%
Is there any way I can hold the feed rate at 100% while the button is active?
Sorry I have been at this for seven hours and probably have not explained myself well here.
Offline borisz
  •  220 220
    • www.poscope.com
Re: Help with Pokeys and Reset Feed Rate
« Reply #1 on: December 18, 2009, 01:06:20 PM »
Hi!
In latest plugin there is FRO with pot integrated already. It has extended mid point for easier setting 100%.
Check if it can suite your needs.
regards
Boris
« Reply #2 on: December 18, 2009, 06:47:52 PM »
Hi Boris,
I really want to be able to just hit a button to reset and hold the FRO at 100 per cent.
Any ideas?
thanks,
Rod
« Reply #3 on: December 18, 2009, 08:53:09 PM »
All fixed
Added a momentary switch to reset FRO
Changed the on/off switch to lock out the pot or enable the pot input.
This seems like a reasonable solution to me because if the on/off switch is activated then the FRO is not changing state - it retains the last override rate from the pot and it is rock solid steady. I was getting a very small 0.01% variation as the pot state was refreshed.
Then once the on/off switch is active the momentary switch can then reset the FRO to 100%.
cheers,
Rod
