Hello Guest it is November 14, 2026, 10:58:50 AM
Author Topic: No LED's for Limits and E-Stop in Mach 3  (Read 7349 times)
« on: December 18, 2009, 09:03:53 AM »
Happy Holidays to All,
My system consist of a CNC4PC C1 ISO board to a Hobby CNC driver board. I've set up and calibrated all Steppers and have manually run the system. Works great, so I wanted to set up my E-Stop and Homing switches. I set up the inputs with pin numbers and port #1 then checked the enable. I jumped the 5V and pin10 input on the C1 board and the LED on that board came on. I then went to the diagnostic screen in Mach 3 and noted that the LED was not on in that screen. To verify that it functioned, I changed the active low and the LED was on. Any help would be appreciated.
Tom
