Hello Guest it is November 22, 2026, 12:21:38 PM
Author Topic: Spindle encoder for cnc lathe conversion?  (Read 29340 times)
« on: December 17, 2009, 07:58:48 PM »
I am starting my lathe conversion and I need to know what I need to purchess for the spindle encoder to use with mach 3 software.
Also do I need any thing else with the encoder to like a eletrical board or does the encoder just go to the parallel port?
Any advice would reall be great!!!!
Thanks Mike ???
Re: Spindle encoder for cnc lathe conversion?
« Reply #1 on: December 17, 2009, 08:14:50 PM »
Mike,
Have a look at the Omron EE-SY672 rande of sensors. The nice thing about these is that they take a wide range of voltage inputs (5V-24V) and have a filter and amplifier built in along with a sensitivity adjustment. It's basically a plug-n-play sensor.
They have reflective ones as well as slotted ones. Have a look at this engineering note.
http://www.homanndesigns.com/EN001.pdf
The sensors can be found here;
 http://au.mouser.com/catalog/catalogUSD/640/1873.pdf
Apart from supplying the sensor with 5Vdc you can just feed it straight into your parallel port, although a buffered non-opto-isolated (sensor contains an opto-isolater) input to a BOB mat be better.
Cheers,
Peter.
Cheers,
Peter.
Homann Designs
« Reply #2 on: December 17, 2009, 08:20:16 PM »
Thanks Peter,
But what is input to a BOB mat be better mean?
Thanks Mike
« Reply #3 on: December 17, 2009, 08:26:39 PM »
Thanks Peter,
Thanks Mike
It might be better to feed the input through a breakout board if you have one.
Cheers,
Peter.
Homann Designs
« Reply #4 on: December 17, 2009, 08:31:04 PM »
Thanks Peter,
Any suggestions on what type of breakout board to get and where I can purchess one?
Thanks Mike
« Reply #5 on: December 17, 2009, 08:36:17 PM »
Thanks Peter,
Thanks Mike
Yes, Mine. :)
http://homanndesigns.com/store/index.php?main_page=product_info&products_id=59
It's a really good solid buffered I/O breakout board.
What stepper drivers to you have?
Cheers,
Peter.
Homann Designs
« Reply #6 on: December 17, 2009, 08:39:11 PM »
I am going to be using compumotor zeta 4 drives.
« Reply #7 on: December 17, 2009, 08:46:21 PM »
Hi Mike,
Had a quick look at the data sheet. The drives should work fine with the MB-02 breakout board.
Cheers,
Peter.
Homann Designs
« Reply #8 on: December 17, 2009, 09:05:49 PM »
Ok thanks again Peter!!!
« Reply #9 on: December 17, 2009, 09:22:44 PM »
Hey Peter, Another question with that encoder what do you need for it to read on the spindle?
I think you mount it so that it reads something on the spindle.Is this correct?
Thanks Mike
