Hello Guest it is November 13, 2026, 12:18:06 PM
Author Topic: Feed Rate  (Read 10270 times)
Feed Rate
« on: December 17, 2009, 03:26:45 PM »
What determines feed rate ? Is it based on the software that is loaded in mach3 to produce the g code?
Re: Feed Rate
« Reply #1 on: December 17, 2009, 03:32:45 PM »
Yes your feedrate is set in your code, for example if your code commands a G1 move it wil also have a feedrate, something like G1X100 Y20 F100.
The F100 is the feedrate which would be inch per min or mm per min depending whether you were using imperial or metric.
