Hello Guest it is November 24, 2026, 01:15:41 PM
Author Topic: M.O.V. for suppression  (Read 11704 times)
« on: December 14, 2009, 11:12:49 PM »
  Anyone out there familiar with using an MOV across a coil for suppression ? TVSS
How do you determine the proper one to use ?
24v - 1.5a coil for example.
Googled around a bit but did not see a reference.
Thanks if you can help,
RC
I tried a diode which worked pretty well but would like to learn more about the varistors.
Re: M.O.V. for suppression
« Reply #1 on: December 15, 2009, 01:28:27 PM »
OK..all better.
I decided to use an R-C Snubber/Suppressor circuit with a 0.1 MFD cap and 100 OHM res.
Does a fine job.
Thanks for looking,
RC
