Hello Guest it is November 13, 2026, 11:52:21 AM
Author Topic: Adjusting Limit Switch  (Read 26054 times)
Offline kolias
  •  1,165 1,165
Re: Adjusting Limit Switch
« Reply #10 on: December 15, 2009, 10:07:03 AM »
Capacitors can be polarised but think that its electrolytic that are. The type you want are suppresion capacitors and are usually ceramic I think.
Not sure what ribbons you are talking about, I was meaning the multi coloured ribbon cables that go between your Bob and drives.
I will get the ceramic capacitor; hope the store will be able to tell me more about them.
The ribbons I cut are the excess ground wire from the motor cables which I had coiled up (see attached pic)
Nicolas
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #11 on: December 15, 2009, 03:28:36 PM »
Good news Hood
I installed the capacitor between the limit switch wires (see pics) and works fine now. I even set the Debounce Interval to zero and all is fine now. Tomorrow I will give it a good work out to make sure that all is fine.
I also tried the Limit Switch Override parameter and that is really cool, thanks for the tip.
What a capacitor does?
Is it possible to install one of them on my motor cables? If yes where do I connect it since I have 5 wires per cable?
Much appreciate your help and time
Nicolas
Nicolas
« Reply #12 on: December 15, 2009, 04:35:17 PM »
Thats great :)
 As to your questions, I am not really qualified to give you explanations of how capacitors work but a quick google search for how does a capacitor work or what is a capacitor  should give you as much info as you wish to have.
 Dont think they would be a good idea on the Step/Dir wires but others can hopefully advise better.
Offline kolias
  •  1,165 1,165
« Reply #13 on: December 15, 2009, 05:25:09 PM »
Thank you Hood
Nicolas
Nicolas
