Hello Guest it is November 19, 2026, 10:39:56 AM
Author Topic: cad cam question  (Read 14802 times)
cad cam question
« on: December 09, 2009, 01:39:10 PM »
say I draw a square in cad and want to drill some holes in it. Do I make a circle the size of the hole or do I just make a point. what does lazy cam or sheet cam like?
Offline docltf
  •  354 354
Re: cad cam question
« Reply #1 on: December 09, 2009, 02:44:29 PM »
point
« Reply #2 on: December 09, 2009, 02:46:00 PM »
thank you!!
« Reply #3 on: December 09, 2009, 03:24:54 PM »
You may want to have a look in the manual ....Tutorial #1 , page 41, Drilling Holes.
Note that you will only get a G81 and need to manualy change the posted code if you want a canned cycle.
Additionaly you may want to create the holes on a seperate layer especialy if you have a number of different hole sizes to be done.
BTW i use circles for the holes in CAD.
« Reply #4 on: December 09, 2009, 03:50:50 PM »
hmm where is that manual? I have been reading the "using mach3mill" I dont see that in there. is there another manual I should have downloaded?
thanks again.
« Reply #5 on: December 09, 2009, 04:10:13 PM »
There is a LazyCam Manual  in the Members Doc's.
« Reply #6 on: December 09, 2009, 04:13:05 PM »
ah. right now i am using sheet cam. have not really looked at lazy cam yet. I dont need to get anymore confused then I already am!!!    ;D
« Reply #7 on: December 09, 2009, 04:43:11 PM »
Well at least you know what LC uses.  :D
