Hello Guest it is November 13, 2026, 01:29:34 PM
Author Topic: runfile not working from macro  (Read 11851 times)
Offline Pich
  •  11 11
« on: December 09, 2009, 11:00:53 AM »
Hi Everyone
I've looked around the forum for an answer but no luck.
I'm running this macro from a an LED button
LoadFile ("c:/mach3/work/patter")
sleep 1000
runfile
When I run the macro within the VB window using the play button it loads and stats the file no problem but when a run it from the LED to start the macro, the macro strts loads the file but does not run.  The only thing I noticed different was that the within the VB window the macro starts on the trailing edge of the button pressed and on the leading edge when using the LED.
John
Re: runfile not working from macro
« Reply #1 on: December 09, 2009, 02:04:49 PM »
What are you meaning by a LED button?
I have just tried it in a VB Button and it works fine.
Offline Pich
  •  11 11
« Reply #2 on: December 09, 2009, 05:58:59 PM »
It works fine on the VB button, I am using Mach MAD to start the macros when I do that it will load but not run
« Reply #3 on: December 10, 2009, 01:18:14 AM »
Ah OK, will test it out when I get to the workshop and see if that happens to me as well.
« Reply #4 on: December 10, 2009, 08:00:08 AM »
I have tried all sorts to get it to work but looks like you will just have to wait until Rev 4 of Mach is out as it should support running macros from external buttons.
