Hello Guest it is November 13, 2026, 07:58:54 PM
Author Topic: Xbox Controller Crashs Mach When Set to "B"  (Read 8126 times)
Offline Katoh
  •  287 287
« on: December 07, 2009, 09:08:07 AM »
Good Evening All
tonight I have come across a problem I'm realy not sure how to solve. I have just ventured into the world of 4 axis machining the rotary axis is around Y. In this case against my last post which I stated you can call this an A axis you cannot its B axis and that's it.
Back to the trouble if you have an Xbox controller fitted  you cant assign the right lever side to side to be Baxis, it will crash Mach, any other axis will work except B, which is the one I need. Why I have no idea. I have gone through every change step by step in changing the settings to accommodated the 4th axis, closed Mach then restarted, until yo change that lever to a B that's it Mach will crash with no way of getting back. If someone can tell me how to get get my settings back of an XML file that wont even load I would be much appreciated, if not I have to start from scratch and calibrate the hole machine again. (NOT A FUN JOB)
Katoh
Katoh
