Hello Guest it is November 13, 2026, 05:11:16 PM
Author Topic: Best way to program pokeys in mach3  (Read 20215 times)
Offline spunk
  •  56 56
« on: December 07, 2009, 05:58:37 AM »
For the moment I connected the pokeys to mach3 using some brains.
This brains consist of an OEMLED2002... connected to a desired function
Is it better to connect the OEMLED from the pokeys to an OEMtrigger in mach and use this trigger for further programming?
seen this typ of programming in Hood's pendant and it made me wander.
Reason for all this is that the pokeys seems to crash my machines, have 3 identical machines running it and all 3 were crashing.
Disconnected to pokeys and all was ok.
Spunk
Offline borisz
  •  220 220
    • www.poscope.com
Re: Best way to program pokeys in mach3
« Reply #1 on: December 07, 2009, 06:12:23 AM »
Hi!
If you want to use only for Pendant, use one from plugin. I am using it on my machine and works fine.
regards
Boris
Offline spunk
  •  56 56
« Reply #2 on: December 07, 2009, 08:37:52 AM »
what do you mean with "one from plug-in"?
which plugin?
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #3 on: December 07, 2009, 09:42:14 AM »
Hi!
I assume that we are talking about PoKeys and Mach.  ;D So the only variant is PoKeys Plugin for Mach.  ;)
"one from plugin": So if we are talking about Pokeys plugin for mach, it should be from that plugin which we are talking about.
Probably the next question will be: "Where can I get that plugin?". The answer is: www.poscope.com
Search for PoKeys55.  ::)
regards
Boris
Offline spunk
  •  56 56
« Reply #4 on: December 07, 2009, 01:00:05 PM »
ok ok point taken
silly me...
Now i do have the latest of pokeys and mach releases...
i have set the inputs up with brains and stuff but perhaps there is a better way of programming then like what i did...
using the OEMLEDs directly to do stuff to outputs and stuff
using an OEMtrigger that is set by the OEMLED from the pokeys and programming the rest with this OEMtrigger?
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #5 on: December 09, 2009, 07:02:56 AM »
I am not so deep in Mach to advice you.
regards
Boris
Offline spunk
  •  56 56
« Reply #6 on: December 09, 2009, 07:06:59 AM »
Thanks for trying to help Borisz
Anyone else have an idea?
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #7 on: December 09, 2009, 08:23:38 AM »
www.cnc4pc.com has manual how to configure Pokeys under Mach.
regards
Boris
