Hello Guest it is November 13, 2026, 07:43:49 PM
Author Topic: XML files  (Read 16116 times)
XML files
« on: November 27, 2009, 12:42:22 PM »
Hi Everyone,
I need to put my old XML files on a new computer. are these settings in the XML folder cold XML back up? do i just replace this folder on to the new computer.
thanks tom
Re: XML files
« Reply #1 on: November 27, 2009, 12:46:49 PM »
No, the xml is in the main Mach folder, it will be called Mach3Mill.xml if using the standard mil profile. If you have made a custom profile then it will be the name of that.xml.
 You could probably use the backups by placing it in the Mach folder and then using the restore settings from Operator menu.
Re: XML files
« Reply #2 on: November 27, 2009, 12:56:56 PM »
Hi Hood,
Thanks for all you help, the port was set to LP3. NOT LP1. i think this did it hope you thanks giving was well
tom
Re: XML files
« Reply #3 on: November 27, 2009, 01:25:44 PM »
Good to hear you got it :)
No thanksgiving here in the UK, think thats only a North American thing but hope you had a good one :)
Re: XML files
« Reply #4 on: November 27, 2009, 07:32:27 PM »
Hi Hood,
Hood i did what you told me to with the XML Restore and it came up with this error. art code 9991
tom
Re: XML files
« Reply #5 on: November 28, 2009, 03:37:08 AM »
Probably because Mach somehow knows they were not the correct backup, ie they were pasted from another computer/install.
 Best thing to do is just use the real xml rather than try the backups.
Re: XML files
« Reply #6 on: November 28, 2009, 04:30:34 AM »
Hood,
That's the problem i cant find the old XLM'S WHAT IF I JUST OPEN THE folder AND PUT all the XLM'S in mach will that work?
tom
Re: XML files
« Reply #7 on: November 28, 2009, 05:18:49 AM »
Yes that would work fine, they are all located in C:\Mach3 and you need to place them in the same folder on the new computer. That is unless you have installed to a different directory than default, if you have done that then it is the main Mach3 folder in the location you have installed.
