Hello Guest it is November 13, 2026, 05:54:00 PM
Author Topic: My CNC pressbrake build  (Read 136628 times)
Re: My CNC pressbrake build
« Reply #40 on: February 05, 2010, 10:40:22 PM »
Parker valves too eh? That's dedication. They should give you a raise.
« Reply #41 on: February 07, 2010, 12:28:08 AM »
I made some spacers to hold the beams parallel. Then started to tack the cross braces into place. I also cut out all the parts for the hydraulic tank on the plas, then welded the tank all up.
« Reply #42 on: February 07, 2010, 01:57:06 AM »
Lookin good. Is that a Mach controlled plasma cutter?
« Reply #43 on: February 07, 2010, 10:19:00 AM »
Yes, it is. It also has a Candcnc mp1000 THC. I built it a few years ago.
« Reply #44 on: February 07, 2010, 10:31:07 PM »
Today I mounted the tank, made the motor and pump mount and also mounted the manifold.
« Reply #45 on: February 07, 2010, 10:59:44 PM »
Machine is looking great I wish I had the time and equipment to build such a nice machine. Keeping posting your updates I enjoy seeing the progress and can't wait to see the finished product. Keep up the good work.
Jason
« Reply #46 on: February 14, 2010, 10:28:56 PM »
Yesterday I got the tank all pressure tested and finished, the backgauge all done and finished all the plumbing. I still need to finish making some support brackets for the hard lines.
« Reply #47 on: February 14, 2010, 10:32:32 PM »
Today I got the electronics started. I mounted the control box, Wired the power supplies and the motor starter. I also cut out a front plate for a small fan and a db25 connector for the MPG. I also cut out a rear plate for the motor power wires, encoders, limits/homes switches and for the valve.
« Reply #48 on: February 15, 2010, 03:43:56 PM »
Looking good. Getting close now.  :)
« Reply #49 on: February 15, 2010, 05:37:23 PM »
Certainly impressive! Nice photo's you've taken and shared with us.
