Hello Guest it is November 19, 2026, 10:05:48 AM
Author Topic: For development  (Read 12034 times)
For development
« on: November 24, 2009, 11:58:42 AM »
It is in relation to the G52, the file TestBoard-10B.nc is a great example I have an object
want to design four pieces on the machine.
In Mach3Mill it shows four objects, very good but has a problem.
In the course of the cutter he does the four objects is only the first object.
In programming VS2003 has subroutine that made the copies of object, you
can make a subroutine to path on top of other objects.
See http://www.cambam.co.uk/forum/index.php?topic=841.0
Note I have VS2005, I do not want the source code for Mach3.
Regards
Armando
« Last Edit: November 24, 2009, 12:00:41 PM by ArmandoM »
Re: For development
« Reply #1 on: November 29, 2009, 06:32:07 AM »
Hi all
My goal is path on top of other objects, in Mach3Mill.
Attached file TestBoard-10B_CV.nc already configured the block.
Any person can simulate the CutViewer Mill, and help me?
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: For development
« Reply #2 on: November 29, 2009, 02:44:23 PM »
This is what I get from your code in Mach3 and also what AlphaCAM makes of it :-
« Last Edit: November 29, 2009, 03:03:58 PM by Graham Waterworth »
Re: For development
« Reply #3 on: November 29, 2009, 06:12:09 PM »
Hi Graham
The problem is to simulate in Mach3.
Run the Mach3 and see trajectory.
