Hello
Guest
it is
November 01, 2026, 10:13:34 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
LazyCam (Beta)
Import Accuracy Of LazyCAM
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Import Accuracy Of LazyCAM (Read 15505 times)
pesbes
5
on:
November 21, 2009, 03:13:46 PM »
I am trying to cut pockets that are very accurate, and was blaming my machine for the inaccuracy of the holes. When I went back to LazyCAM to try again, I noticed that the error seems to be in the LazyCAM import. For example: 5 circles drawn in CorelDRAW are defined to be .995" in diameter. When those are imported into LazyCAM, they vary in diameter from .9547 to .9557 or .001. In fact some of the circles are not even circular any more as the diameter and the diameter are off by .001 also. Is there a way to set accuracy of import or am I doing something wrong.
Thanks for your help. I am new to this site.
pesbes
Logged
Re: Import Accuracy Of LazyCAM
Reply #1 on:
November 21, 2009, 04:15:50 PM »
pesbes,
See section 6.2.3 in the manual, line tolerance, and use a very small value, but ......
if there are gaps between lines or points, then you may have another issue.
I am very curiuos, Can you post your DXF file?
Logged
ger21
6,295
Reply #2 on:
November 21, 2009, 04:39:03 PM »
More than likely it's the way that Corel is doing the exports. Posting the .dxf will let us confirm this. For best results when using Corel, you should look into getting the Corel .dxftools.
http://www.coreldrawtools.com/
Logged
pesbes
5
Reply #3 on:
November 21, 2009, 05:39:42 PM »
I do not use the save as DXF function in Corel, I have been using the Save as PLT function. Don't know why I use PLT, so I went back and tried DXF and when I import into LazyCAM it locks up. Now I remember why I have been using PLT.
Logged
pesbes
5
Reply #4 on:
November 21, 2009, 05:48:22 PM »
I also tried the suggestion of changing the gap tollerace to a small number. It was at .001 and now it is .0001, but I get the same result.
Logged
pesbes
5
Reply #5 on:
November 21, 2009, 06:02:09 PM »
I tried a new experiment using a different package to export the DXF file (CadStandard). It produced the correct size circle when imported into LazyCAM. Now I just need to figure out how to get the Corel package to export to DXF in a file LazyCAM can read. When I imported the Corel output file into my CAD package, the circles were multiple pieces and had one section that did not look right. I think the whole problem is Corel.
Logged
ger21
6,295
Reply #6 on:
November 21, 2009, 06:02:13 PM »
99.9% sure your problem is with Corel's export.
Logged
pesbes
5
Reply #7 on:
November 21, 2009, 06:25:47 PM »
Looked at the Corel Draw tools you suggested, but my version of Corel is too old (V9). Not sure I want to spend the $150 to upgrade.
Logged
Reply #8 on:
November 21, 2009, 07:38:37 PM »
pesbes,
Corel seems to still be a paint program from days of old. I may be wrong , haven't used it in a long time, but the dxf capability out of it leaves something to be desired. My opinon, from has been posted before.
Logged
Print
Pages:
1
Go Up
« previous
next »
