Hello Guest it is November 13, 2026, 10:01:47 AM
Author Topic: Z late getting to final depth  (Read 16390 times)
« on: November 20, 2009, 11:01:12 AM »
Hi, Let me start out saying I'm new to Mach. I have just finished building my table and have a problem. Whenever I start to make a cut my Z axis doesn't get to it's final depth before x and y start to move. It will get there, but the first part of the cut is shallow.
Joe
Re: Z late getting to final depth
« Reply #1 on: November 20, 2009, 12:12:37 PM »
Pretty much has to be the way the g-code is written.
G1 X1 Y2 Z-0.5  - will move all three axes at once, so the tool ends up at X1, Y2, Z0.5 at the end of the move
G1 Z-0.5
G1 X1 Y2  - will move Z to -0.5, *then* move X/Y
« Reply #2 on: November 20, 2009, 12:41:07 PM »
I think it could also be CV mode. I saw this over the weekend when cutting some parts. With CV mode, the X and Y start moving before the Z stops.
« Reply #3 on: November 20, 2009, 10:05:56 PM »
I did change it from CV mode but cut was real jerky. I've been getting the G codes via Lazycam. Could it be a setting in LC?
Joe
« Last Edit: November 20, 2009, 10:07:43 PM by jbjackson »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #4 on: November 20, 2009, 11:30:10 PM »
Hi, Joe
Post your problem G-code and DXF files your having issues with, Use the REPLY button and Attach option, Welcome aboard.
Chip
  •  9,377 9,377
« Reply #5 on: November 21, 2009, 02:29:34 AM »
If you are using LazyCam then it will create the Z axis leadIn's unless you set the 'LeadIn size' to zero or uncheck the 'LeadIn on' box. (under the 'layers' tab click 'layer leadin settings').
