Hello Guest it is November 25, 2026, 07:14:56 AM
Author Topic: Shuttle plugin won't go away  (Read 11537 times)
« on: November 18, 2009, 08:47:01 PM »
I've been doing a lot of tuning with my Mach system lately, and getting very positive results.  I am using the latest available build Mach3 R3.042.032  with a Smooth Stepper and a G540, latest plugin for that as well. Thing is, every time I start Mach3 I get a message flashed about there being no Shuttle in the system, I go to plugin config and disable the Shuttle Plugin,  and do a Save Settings, but the next time I start Mach there it is again.  I would really like to be able to permanently disable this, and I'm not sure if I need some of the other ones as well.  Is there a way to get rid of this plugin, or at least make the setting stick?
Re: Shuttle plugin won't go away
« Reply #1 on: November 18, 2009, 08:55:11 PM »
What I do is just create a subdirectory below where it is located  and move the dll there. Now it is removed but not lost should i ever want to put it back.
« Reply #2 on: November 18, 2009, 09:07:27 PM »
Super, worked like a charm.  Thanks!
