Hello Guest it is November 13, 2026, 12:52:49 PM
Author Topic: Motor/driver ID  (Read 22317 times)
Offline markn
  •  29 29
Motor/driver ID
« on: November 18, 2009, 07:48:24 PM »
Hi Guys,
I have a AC Servo motor, labeled Velconic AC Servo, the motor has 3 power leads and also what appears to be an encoder attached to the end. The encoder shell has 7 twisted wire pairs on the wiring harness, when I rotate the shaft by hand it "cogs" almost like a stepper motor.. The model # is RA13M1-0200E 13M1-0200E. Anyone know type of motor this is and what sort of drive it would need?
Re: Motor/driver ID
« Reply #1 on: November 19, 2009, 06:41:51 AM »
It is  an AC Servo, does the cogging only happen at three or four points? If so than that is the amount of pole pairs it has.
You would need an AC or Brushless DC drive for it, what make/model will all depend depend on the current and voltage ratings.
« Last Edit: November 19, 2009, 06:44:01 AM by Hood »
Offline markn
  •  29 29
Re: Motor/driver ID
« Reply #2 on: November 19, 2009, 08:00:37 AM »
Hi Hood,
The cogging action feels more like every 1 degree, almost like a MPG.
Thanks, mark
Re: Motor/driver ID
« Reply #3 on: November 19, 2009, 08:08:44 AM »
Well it kind of sounds like the bearings are shot, an AC servo should rotate fairly smooth but you would feel a slight but definite pull as it gets near a pole.
Offline markn
  •  29 29
Re: Motor/driver ID
« Reply #4 on: November 19, 2009, 08:15:19 AM »
Hi Hood,
No the feeling is not like that of a bad bearing at all, the motor shaft rotates smoothly. I think there must be some kind of magnetic stator.
Re: Motor/driver ID
« Reply #5 on: November 19, 2009, 08:26:17 AM »
The AB "N-Series" motors are very similar to this...sort of like a very coarse stepper but a bit softer between the detents.
They call it a "ring magnet rotor construction" motor.
Offline markn
  •  29 29
Re: Motor/driver ID
« Reply #6 on: November 19, 2009, 08:35:33 AM »
Yes, That describes it perfectly. So what sort of driver is required?
Re: Motor/driver ID
« Reply #7 on: November 19, 2009, 08:38:27 AM »
Like Hood said....you need to get more info on it.
Also, the type of commutation required.
Re: Motor/driver ID
« Reply #8 on: November 19, 2009, 08:52:14 AM »
A quick search only showed 2 Velconic amplifiers/drives.
Only about $200 difference in price.
Here is the higher $ of the 2.
RC
Re: Motor/driver ID
« Reply #9 on: November 19, 2009, 08:55:37 AM »
Seems like its Toshiba, found some info on their Australian site but not for these motors. :(
