Hello Guest it is October 23, 2026, 07:48:19 PM
Author Topic: Installation Mach3 3.042.032  (Read 14966 times)
Offline asrin
  •  19 19
« on: November 17, 2009, 06:28:59 AM »
Hi
On my computer was installed Mach3 version R3.037 and I have updated to version 3.042.032. But now I have a problem. When I want to edit my G-code, the editor starts up very, very slow and typing in the editior is also very slow. Saving etc.
Mach3 works further fine.
I de-installed Mach3, also the  Mach3 folder on the C drive and the the driver in the divice manager.
I have reinstalled Mach3 version 3.042.032, but the computer don't ask for rebooting. Is this normal, so the problems are still the same as before. Or are there still files, I have to delete?
Anybody knows what's going wrong?
With kindly regards from the Netherlands
Re: Installation Mach3 3.042.032
« Reply #1 on: November 17, 2009, 07:31:54 AM »
It is normal for it not to reboot if you have had Mach installed previously as the reboot is only needed the very first time.
Afraid I dont know what your problem with the editor is, works fine here. Only thing I can suggest is see if opening a notepad document from windows rather than Mach is OK. The other thing would be to check on General Config page that the location of notepad is correct, although I think it must be or dont think it would open at all.
Offline asrin
  •  19 19
« Reply #2 on: November 17, 2009, 08:04:27 AM »
Hi Hood,
Thanks for the quick reply.
I found out what the problem wreak.
For some in / ouputs I use the Pokeys. The Pokeys plugin for Mach3 is not the problem, but when I pull out the USB plug of Pokeys, Mach3 and notebook works fine. When I Install the Pokeys USB plug, the problem is there.
In the Pokeys forum I can't find an answer. I use the latest software for Mach3 and Pokeys.
Riny
« Reply #3 on: November 17, 2009, 04:15:14 PM »
Try an older plugin for the Pokeys and see if that helps.
