Hello Guest it is November 19, 2026, 09:11:31 AM
Author Topic: Trying to add pattern to pool cue handle, Need help with procedure  (Read 9439 times)
Greetings, I am trying to add a pattern to a pool cue handle.  I am using a CNC router with a 4th axis.
I need help with the procedure. Should I draw the pattern in 2D within a trapezoid the area of the handle and connect the X axis stepper control output to the A axis stepper. Or should the pattern be drawn in 3D?  I have no experience with using a 4th axis. This should be a great learning experience.
This is my first attempt and any input will be greatly appreciated.
Re: Trying to add pattern to pool cue handle, Need help with procedure
« Reply #1 on: November 14, 2009, 07:10:28 PM »
Hi, I do not know if you heard about wrapper but you should take a look at it.
Do a search on wrapper on this site.
http://www.machsupport.com/forum/index.php/topic,12749.0.html
it is only $20,00
You draw the pattern you want and let wrapper sort Gcode for the 4th axis.
Hope this help
Jeff
