Hello Guest it is October 20, 2026, 09:57:37 PM
Author Topic: 2nd parallel card  (Read 10652 times)
2nd parallel card
« on: September 09, 2006, 12:08:32 AM »
If I set up a second parallel port card, am I still limited to pins 10,11,12,13, and 15 for inputs or can I use them all?  The reason I ask this is I want to set a different input for each limit switch so I knoe exactly which one has been tripped.
Re: 2nd parallel card
« Reply #1 on: September 09, 2006, 12:14:53 AM »
If you have a second port you can opt to use pins 2-9 as inputs, just put a tick in the box on the ports and pins main page for the second port.
« Reply #2 on: September 09, 2006, 12:35:42 AM »
Thanks, that is what I though. I just wanted to confirm before I went ahead
