Hello Guest it is October 21, 2026, 09:02:48 AM
Author Topic: Smoothness EXTREME need of help  (Read 53957 times)
Re: Smoothness EXTREME need of help
« Reply #30 on: November 13, 2009, 02:43:04 PM »
CV feedrate = +1
Increase your CV feedrate to the same value as your normal feedrate. Set the CV distance to 1 to 3 if you are in mm and to .05 to .15 if you are in inches.
« Reply #31 on: November 13, 2009, 02:53:57 PM »
And make sure your CV distance and CV feedrate leds is on.
« Reply #32 on: November 13, 2009, 03:41:53 PM »
how do i change the cv feedrate?
« Reply #33 on: November 13, 2009, 03:46:36 PM »
Enter the desired CV feedrate in the DRO next to the CV feedrate button on the setting page, then hit enter.
« Reply #34 on: November 13, 2009, 03:46:43 PM »
wow!
That did it.
I cant believe that all i had to do was increase the CV rate.
What does CV stand for and what does it do?
Thank you very much.
« Reply #35 on: November 13, 2009, 04:01:12 PM »
The CV feedrate is the maximum allowed feedrate when Mach3 is "cutting corners". Mach slows down to this feedrate if it's lower than the programmed feedrate when cutting corners in constant velocity mode. If this feedrate is to low Mach behaves almost as in exact stop. A feedrate of 1 (inches or mm) per minute is VERY slow and makes the movement almost like exact stop.
You also may want to uncheck the "Stop CV on angles > x Degrees" under the Config > General Config menu page.
« Reply #36 on: November 13, 2009, 04:10:39 PM »
The phrase "CV" stands for Constant Velocity.
