Hello Guest it is October 17, 2026, 07:08:21 AM
Author Topic: Smoothness EXTREME need of help  (Read 53877 times)
Re: Smoothness EXTREME need of help
« Reply #10 on: November 12, 2009, 05:21:30 PM »
LOL I never even noticed the M01's
Sometimes you can't see the forest for the trees................................. or you are blind like myself and Hood.  ;D
« Reply #11 on: November 12, 2009, 05:22:54 PM »
blind, deaf and dumb oh and bald as well ;D
« Reply #12 on: November 12, 2009, 05:30:13 PM »
Even with those mods in the G-code, the machine still does the same thing.  It follows the straight line at first, pauses for fraction of a second, then proceeds to make the arc and pauses again before making the horizontal line.
After the glue is dispensed, my rectangle is created with little piles of excess glue in the corners.
What can i DO?
Offline docltf
  •  354 354
« Reply #13 on: November 12, 2009, 05:31:29 PM »
no excuse for baldness with use of the modern glue.
« Reply #14 on: November 12, 2009, 05:36:30 PM »
What can i DO?
possibly you will have to modify the speeds of the corners or adjust the rate of flow of the glue.
LOL
Offline docltf
  •  354 354
« Reply #15 on: November 12, 2009, 05:40:05 PM »
check the look ahead setting in general config menu and make sure it is set for more lines than one.
« Reply #16 on: November 12, 2009, 05:41:37 PM »
what does the look ahead command do?
« Reply #17 on: November 12, 2009, 05:45:18 PM »
it looks ahead LOL
if its set to 1 then that will definitely be a problem butI think the default is 20 so it will only be lower if its been changed.
« Reply #18 on: November 12, 2009, 05:53:16 PM »
It was set at 20.  I changed it 50 and then 1 and then 20 again and no difference.
Offline docltf
  •  354 354
« Reply #19 on: November 12, 2009, 05:53:38 PM »
what are you drinking hood
