Hello Guest it is November 16, 2026, 04:12:12 PM
Author Topic: The plasma cutter fire up and the G320X drivers faulting  (Read 9817 times)
« on: November 12, 2009, 03:33:45 PM »
Hi every body
If anyone can help me will be much appreciated.
I have a plasma table with 4 G320X servo drivers.
When the plasma touches the material and the arc starts the driver’s faults.
The fault clearly comes from the drivers not from the PC.
If I keep the err/res connected with the 5v pin of the G320X driver all the time,
The drivers faulting when the plasma start but second after become green again.
So the problem I assume is only at the plasmas ignition not wile cutting.
