Hello Guest it is November 19, 2026, 08:25:16 AM
Author Topic: Mill a straight line  (Read 9538 times)
« on: November 10, 2009, 07:28:28 PM »
They say there's no such thing as a stupid question but this one is close. I need to mill a simple straight line the width of whatever diameter cutter I have at hand. Basically I'm milling some elliptical holes inside of a rectangle 1 in. by 8 in. from a 8 in. x 8 in.  brass plate. I just need to "part off" the 1 in. x 8 in. piece when the ellipses are milled. I could do it manually but that's no fun. I could draw a rectangle, import it into Lazycam and use outside offsets but that means the cutter will be cutting air on 3 sides. That's no fun either.
I've got a 12 in. x 12 in. piece of aluminum that I'd like to cut up to make a tool plate so the ability to have the Taig mill a simple straight line seems like a very basic task. Any thoughts?
Re: Mill a straight line
« Reply #1 on: November 10, 2009, 09:10:49 PM »
Position the part and cutter where you want, then in the MDI line
G01 X 8.0" F1.0
G01 -thats a linear interpolation move, X8.0 - the X axis will move 8.0 units, F1.0 - at a feed rate of 1.0 ipm.
You change the axis, the  travel distance  and feedrate to suite what your doing.
