Hello Guest it is October 21, 2026, 06:34:19 PM
Author Topic: entering info in gcode  (Read 15058 times)
« on: November 09, 2009, 07:55:07 PM »
is it possible to have an info line in a program, let's say to tell me which tool to change to when needed.
Re: entering info in gcode
« Reply #1 on: November 09, 2009, 08:02:39 PM »
Just put it n parenthesis.
(Change tool)
« Reply #2 on: November 09, 2009, 08:04:20 PM »
as easy as that, thanks ;D
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #3 on: November 10, 2009, 08:44:16 PM »
Dont you have to be careful where you put the parenthesis? Like it has to be alone or it is a subprogram? Mine throws an error if already inside a set of parenthesis.
« Reply #4 on: November 10, 2009, 09:21:20 PM »
N10 (REMEMBER IT IS TIME TO CHANGE THE TOOL)
Just like above, the N10 is just a line number, you shouldn't get an error.
Offline alenz
  •  137 137
« Reply #5 on: November 12, 2009, 04:57:00 AM »
Yes mach doesn’t allow nested parenthesis in a comment, why I don’t know.
But you can use parentheses inside a comment if you start the comment with a semicolon such as:
N10 ;A macro containing xx(xx) is required for this file
Will work just fine.
Al
« Last Edit: November 12, 2009, 04:59:44 AM by alenz »
