Hello Guest it is November 19, 2026, 08:17:22 AM
Author Topic: Swap x and y axes  (Read 10540 times)
Swap x and y axes
« on: November 07, 2009, 06:47:46 PM »
Ok, need a little help here.  I recently set up one of my machines with a double router head, and now I am running 1x4 signs "vertically" instead of "horizontally" on that machine now.  Instead of reprogramming everything, is there a g code command I can use to swap the x and y axes?
For example, if I run a 4' 1x4 sign that says "Welcome to our Home", I usually run that sign along the x axis, just as if you're reading it.  I want to put a command at the front of that toolpath that would cause it to run along the y-axis, so it would basically just swap the x and y axis coordinates throughout the whole program.
Can anyone help?  I need to know by Monday!
Bill
Re: Swap x and y axes
« Reply #1 on: November 07, 2009, 07:26:50 PM »
Set up a new Mach profile with the axis flipped.
« Reply #2 on: November 07, 2009, 09:03:39 PM »
Where are the settings for that?
Thanks so much
Bill
« Reply #3 on: November 09, 2009, 07:34:35 PM »
got it figured out and ran it all day with no problems.  thanks for the idea. ;D
