Hello
Guest
it is
November 19, 2026, 09:04:36 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
meshcam
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: meshcam (Read 11395 times)
johnygoodwood
4
meshcam
on:
November 07, 2009, 05:02:53 AM »
hi all
please help i use solidworks to draw save as dxf import to curve cut then post to mach2 not a problam
but i need to do 3d and have meshcam i save files in stl open meshcam and then get very lost dont know if i have to post it to mach3 or use meshcan direct to machine
any pointers would be helpfull many thanks john
Logged
ger21
6,295
Re: meshcam
Reply #1 on:
November 07, 2009, 05:40:33 PM »
In Meshcam, you need to create the toolpaths. When they are created, a dialog box will pop up asking you to save the G-code. Use the Mach post, and open the g-code in Mach3.
Logged
johnygoodwood
4
Re: meshcam
Reply #2 on:
November 14, 2009, 01:04:22 PM »
thankyou that worked
Logged
johnygoodwood
4
solidworks
Reply #3 on:
November 14, 2009, 01:11:05 PM »
does anyone know how to import jpg or bmp into a part say as background so i can impose on the face i want to sketch ie use splines
to draw then extrude them want to draw celtic knots many thanks donegal john
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: meshcam
Reply #4 on:
November 14, 2009, 03:13:20 PM »
I don't know what system you are using but I use the emboss command to do that type of thing, I pick an area, paste an image into it, then emboss the image.
May give you some clues, it may not
Graham
Logged
Print
Pages:
1
Go Up
« previous
next »
