Hello Guest it is November 07, 2026, 02:53:43 PM
Author Topic: CNC drivers fighting...  (Read 11572 times)
« on: November 05, 2009, 08:07:55 PM »
Has anyone experienced issues with having two CNC control programs on the same machine?  We are thinking that the drivers from each program are not getting along and causing noise which is making the steppers wiggle and move but no movement is seen on the DROs.
Re: CNC drivers fighting...
« Reply #1 on: November 05, 2009, 09:19:35 PM »
Are you running two different control programs or do you mean multiple installations of Mach on the same machine?
« Reply #2 on: November 05, 2009, 09:35:13 PM »
Two different programs.  The first program that came with the router was Liberty CNC.
  •  9,375 9,375
« Reply #3 on: November 06, 2009, 08:06:00 AM »
To get the best results from Mach, it is like Rich has said, you should use a dedicated PC running Mach and nothing else. This way no problems will be experienced.
