Hello Guest it is November 13, 2026, 09:39:34 PM
Author Topic: Dpad interface questions.  (Read 14436 times)
Offline Psad
  •  82 82
« on: September 07, 2006, 05:25:01 PM »
Iinstalled a Dpad (cheap wired type) on my Mach3 machine for jogging table and Z.
that part was easy with Keygrabber since they are specific keys.
I would like to program the following functions into this dpad, can someone tell me the Key sequence to
JOG speed +
Jog speed -
E stop
Offline Psad
  •  82 82
Re: Dpad interface questions.
« Reply #1 on: September 08, 2006, 12:51:19 PM »
TO Art
I found the keyscan codes for the above functions.  estop=192,  jogs speed - = 112, jog speed + = 111.
How can i get these into Key Grabber.  It appears to be looking for a Keypress and will not let me do manual entry.
Is there a workaround.  Sorry to be a problem but i'm learneing a lot.
« Reply #2 on: September 12, 2006, 09:34:20 AM »
If I was you I would just reprogram it to what you would like it to be... You can reprogram the hot key in Screen 4
Hope that helps
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline Psad
  •  82 82
« Reply #3 on: September 16, 2006, 07:26:26 AM »
Brian - If i reprogam the hot key for estop, will that change stay or will i have to reprogram evey time i download a new version ???
« Reply #4 on: September 16, 2006, 04:13:39 PM »
it will stay that way as long as you keep using the same screen set.
« Reply #5 on: September 16, 2006, 04:27:31 PM »
BTW
112=F1
111 = / (this is the / on  the numeric part of the keyboard)
192 = '
