Hello Guest it is November 22, 2026, 09:42:02 AM
Author Topic: New REV  (Read 23275 times)
New REV
« on: November 05, 2009, 01:51:03 PM »
For those of you who do not frequent the Yahoo group, this is just in from Brian.
"This is the first rev after the move and I am pleased to see that no
more then a week after the move we can have a release out!
This rev has the following changes :
1.)Probe is now working like it did in older versions of 3.*********.*********
2.) threading has been fixed for the last time :) This was a MAJOR
update to threading and if you have a lathe this is a MUST have rev!
3.) GetMachVersion() call has been added to VB so you can tell what
version of Mach3 you are dealing with
4.) SetToolDesc() call added to VB for setting the tool description in
the tool table from a script.. This was needed for testing the new
screens.. Also this will be added to the Rev 4 calls as well..
I am in hopes that this is the last Rev of version 3 we will be doing
so we can start working only on Rev 4. The Rev 4 code is at the point
that I can test a machine now :). I have sent out the header file so
Scott S. can test the new plugin interface. I suspect he is going to
have a list a mile long of vars that I didn't add.. O well, we will get
it over time!
Time for lunch here and Please tell me if you see anything that is not
what you would expect in Rev 3
Brian"
Looks to be a "MUST" for TURNERS/THREADERS !
RC
Re: New REV
« Reply #1 on: November 05, 2009, 01:55:13 PM »
If you'd like to follow the thread.....
http://groups.yahoo.com/group/mach1mach2cnc/message/114494
RC
Re: New REV
« Reply #2 on: November 05, 2009, 03:27:06 PM »
Where is the new rev posted?  ??? The DOWNLOADS is still .029.
Re: New REV
« Reply #3 on: November 05, 2009, 03:50:26 PM »
refresh your browser ;)
Re: New REV
« Reply #4 on: November 09, 2009, 09:45:22 AM »
My version reads R3.043.000 is there a later version ?
Dennis
Re: New REV
« Reply #5 on: November 09, 2009, 11:36:59 AM »
You shouldn't really be using Ver 043 as it was just a special test version for the new comp code and has quite a few problems.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: New REV
« Reply #6 on: November 09, 2009, 12:11:13 PM »
Hi, All
New revision under Downloads above.
Chip
Re: New REV
« Reply #7 on: November 09, 2009, 02:33:39 PM »
Hood it's under lock down version.
Dennis
Re: New REV
« Reply #8 on: November 09, 2009, 02:46:03 PM »
Dennis
R3.043.000 is not the lockdown, in fact it is no longer there, that was a test version as I said above and was only ever a Dev version.
The lockdown is R3.042.032
Re: New REV
« Reply #9 on: November 09, 2009, 07:35:14 PM »
Thanks Hood I will install that ver.
Dennis
