Hello Guest it is November 07, 2026, 02:31:42 PM
Author Topic: z+ z- move  (Read 15402 times)
Offline jve
  •  128 128
z+ z- move
« on: November 05, 2009, 05:39:43 AM »
hi guys
is it posible in mach 3 to make 2 buttons z+ z- to jog but i need these two buttons work while the g code is running
Offline klmark
  •  107 107
Re: z+ z- move
« Reply #1 on: November 05, 2009, 08:42:46 AM »
Yes it is possible I do it all the time on my flame torch If I understand right you want to fine tune the z Axis while running g code
Offline jve
  •  128 128
Re: z+ z- move
« Reply #2 on: November 05, 2009, 10:21:55 AM »
ok good
but can you tell me how ;D
Offline klmark
  •  107 107
Re: z+ z- move
« Reply #3 on: November 05, 2009, 10:58:35 AM »
No I will help anyway I can Go to config ports and pins input signals  in input signals stroll the to  THC UP and THC down  enable both enable Emulated then set a hotkey for up and down this will control your up and down with the keyboard hit apply and go to Mill Options check mark Allow THC UP/DOWN Control even if not in THC mode hit apply and OK your ready to go
Offline klmark
  •  107 107
Re: z+ z- move
« Reply #4 on: November 05, 2009, 11:01:41 AM »
Also do a search of ( Jogging Z axis while machine is cutting ) that will help you on this forum
« Last Edit: November 05, 2009, 11:04:09 AM by klmark »
Offline jve
  •  128 128
Re: z+ z- move
« Reply #5 on: November 05, 2009, 11:10:09 AM »
OK i allready did that but the problem is that while it is moving the z axis it does not remember the correction so then you have to correct again when you have the next z axis move for example lets say i have a cutting height of 5mm and i make a correction of a 1mm down so the z dro is reading 4mm after when you have the next g code that say g0 z5 it will go to z5 and not z4mm so the correction must be in the offset then
Offline klmark
  •  107 107
Re: z+ z- move
« Reply #6 on: November 05, 2009, 01:36:52 PM »
Well that is all I can help that is how I us it I like to fine tune on ever z plung
Offline Fastest1
  •  920 920
  • Houston, TX
Re: z+ z- move
« Reply #7 on: November 05, 2009, 10:57:14 PM »
how about edit the gcode? Find and replace?
