Hello Guest it is November 23, 2026, 04:08:48 AM
Author Topic: Installation problems - No Driver Sensed Installed. Run Driver Test  (Read 24126 times)
cpm914
I'm having trouble getting Mach 3 installed.
The software seems to install and then errors on the driver install at the end.
When running drivertest.exe I get the "No Driver Sensed Installed.  Run Driver Test"I have tried to manually install the driver but get the following -
"An error ocured during the intallation of the device.
The system cannot find the file specified"
I can see the file but the cumputer starts downloading the Mach3.inf file and then halts.
I have uninstalled and reinstalled the software a few times and  trying to get past this but No luck.
I have checked the system with Spybot and no problems.
Any body have any ideas?????
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: Installation problems - No Driver Sensed Installed. Run Driver Test
« Reply #1 on: September 06, 2006, 08:42:00 PM »
what operating system are you trying to install on?
chad
cpm914
« Reply #2 on: September 07, 2006, 10:33:45 AM »
Win XP
« Reply #3 on: September 10, 2006, 09:00:50 PM »
I have the same problem. I un-installed and reinstalled program several times. I cannot remove the driver manually because it does not seem to be installed, at least not where the manual says it can be found. I hunted down and removed the Mach3.sys file from the system directory and tried to manually install  a new one. The installer reports a file not found error after opening the inf file.
I am dead in the water until I get this resolved!
There must be a hook in the registry that can clear this up.
any ideas anyone?
Thanks.
Bill
Pixel Tamer
« Reply #4 on: September 10, 2006, 11:09:03 PM »
Resolved the problem using XP system restore command to undo the latest update. It then allowed me to install the latest software and driver.
See: Start/programs/accessories/system tools/system restore.  Hopefully you have a recent restore point that does not undo too much. Restore does not remove data files.
Thanks.
Bill
Pixel Tamer
« Reply #5 on: September 12, 2006, 10:24:23 AM »
Are you un checking the Install Driver at the end of the install?
www.newfangledsolutions.com
www.machsupport.com
« Reply #6 on: September 12, 2006, 01:14:49 PM »
Learned my lesson.. never install the driver a second time.
Yes I had clicked on install the driver option, but forgot to reboot because I though it would not overlay or mess up the one already installed. I had it running yesterday. I am not sure what I would have done without the option to revert to an earlier XP setup.
Bill
Pixel Tamer
