Hello Guest it is November 01, 2026, 10:12:43 AM
Author Topic: Zooming  (Read 27821 times)
Zooming
« on: November 02, 2009, 03:43:45 AM »
Hi there,
I,m using Lazycam for a few day's now, but when I follow the two video tutorials I get stuck at the end of the second video tutorial.
After setting the depth and number of passes to go deeper in the material, I should rotate the drawing so I can see the steps the mill should make to go deeper in the material. (a sort 3D view)
I can't figure out how to see the drawing in 3D in lazycam. Has anybody the solution how to see the drawing in 3D in LazyCam ?
Best regards
Chris
Re: Zooming
« Reply #1 on: November 02, 2009, 04:09:10 AM »
Hi Chris,
Haven't used LCam for awhile but try holding down the mouse wheel(third mouse button) and dragging.
Re: Zooming
« Reply #2 on: November 02, 2009, 05:25:52 AM »
I tried that already, nothing happens when I try that.
Chris
Re: Zooming
« Reply #3 on: November 02, 2009, 09:00:51 AM »
See section 5.1 in the LC manual on how to manipulate the graphics.
Re: Zooming
« Reply #4 on: November 02, 2009, 10:11:01 AM »
Chris
Interesting, now that I'm home and tried it, it works perfectly for me here?
Re: Zooming
« Reply #5 on: November 02, 2009, 11:50:21 AM »
Rich,
Manual, where to find it ??
I have Lazycam 3.00.2 and installed also the update.
I start Lazycam in the menu from Mach3
I figured out that with R I can zoom maximum window
With Shift and the mouse I can zoom
With Ctrl and the mouse I can move the drawing
But still no way to see 3D drawing.
Re: Zooming
« Reply #6 on: November 02, 2009, 11:57:19 AM »
Do you have a mousewheel that clicks down as the 3rd button?  If so, are you holding it down while dragging?
Let's do a little test here. Go onto a webpage or something that has a lot of text. Now click the mouse wheel down once (not holding it) and see if you get that circle with the up and down arrow with the dot in the center. If you don't there's an issue with the mouse. If you do, then just move the mouse closer to you and away from you. Is the page of text scrolling?
If so, there's no reason why 3D should not work, maybe it's a driver issue but I thought all 3 button wheel mice were pretty standard nowdays.
EDIT: LCAM Manual in the Members Docs area:
http://www.machsupport.com/forum/index.php/topic,12078.0.html
« Last Edit: November 02, 2009, 11:59:33 AM by budman68 »
Re: Zooming
« Reply #7 on: November 02, 2009, 12:26:33 PM »
With a normal mouse it works, but al my systems are using LOGITECH Marble mouse (not enough space to move a normal mouse on the table), there's no 3e button on the marble mouse.
Is there a wat to manipulate this by  the keyboard ?
Chris
Re: Zooming
« Reply #8 on: November 02, 2009, 12:27:57 PM »
Sorry, not that I know of, Chris-
Re: Zooming
« Reply #9 on: November 02, 2009, 12:51:43 PM »
Thanks for you're help,
I will figure out how to fix it another way. (The 3e button is clicking left and right button at the same time. Yhat works in any web page, but LCam is using then only the right button.
Chris
