Hello Guest it is November 19, 2026, 07:49:17 AM
Author Topic: I can't load all of my lines of g-code  (Read 9252 times)
« on: November 01, 2009, 01:32:40 PM »
Hi Guys,
I am real new to all of this.  I have 1600 lines of g-code created,  when I load it into mach3 I only see around 420 lines (each time I load it A different number of lines will show up)  If I click edit g-code all 1600 lines are there???  If I run the g- code it stops at the last visible line....What in the world am I doing wrong???  I can make a great 1/4 of a part.
Troy
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: I can't load all of my lines of g-code
« Reply #1 on: November 01, 2009, 04:44:37 PM »
If you are using the demo version it has a line limit, the full version has not.
Graham
« Reply #2 on: November 01, 2009, 05:12:45 PM »
I am running the licensed version.  If I load the default mill profile everything is OK.  When I load my profile only 500 lines???  I must have something configured wrong.  The About Mach3 shows my license.
