Hello Guest it is October 21, 2026, 10:03:05 AM
Author Topic: How to use Relays on the 106 I/O board  (Read 17474 times)
Offline Boots
  •  17 17
« on: November 01, 2009, 11:40:08 AM »
How do I control relays example:
M7 turns on Relay 2
How do you control Relay 3 through 8?
On my old Centroid machine M94/4 turned on Relay 4. Mach3 does not use M94 commands.
Also How do I assign the relay on command to the user buttons?
Thanks for your time, Boots-2b1
Re: How to use Relays on the 106 I/O board
« Reply #1 on: November 01, 2009, 01:00:36 PM »
All depends what you are wanting to do with the relays but user macros or brains may be what you are looking for.
 If you give an example of what you want to do then I am sure someone will point you in the right direction.
Offline Boots
  •  17 17
« Reply #2 on: November 02, 2009, 09:43:56 PM »
Hi Hood,
I have Cool Air, Mist, Flood, Light, Hold downs controlled by two relays etc. On my other system CNC4 I issued a M94 code in my g-code to close my relays. Example: if the light was connected to Relay 4 In my code I would issue a M94/4 and it would turn on the light. Mach3 does not support the command M94 - so what command do I was to close relays 4-9? I am a electronics engineer, the relays are wired correctly.
Boots-2b1
« Reply #3 on: November 03, 2009, 01:50:56 AM »
You will need to write custom macros and place them in the macro folder of the profile you are using.
The macros will be from 100 upwards for custom macros so you could, for simplicity, have m104, m105, m106 .........m109 and that would kind of work like before for your 4 to 9 relays. Also setting the relays to Outputs 4 to 9 in Ports and pins would also keep things easily remembered.
 So to summarise you would set the relays to outputs in Ports and pins, you would open notepad and write a macro, example for Output 4 below
ActivateSignal (OutPut4)
You would then save it as m104.m1s in your profiles macro folder and thats it.
 You can then  call from code or MDI ust like you did before except it would be m104
Offline Boots
  •  17 17
« Reply #4 on: November 03, 2009, 11:59:15 PM »
Hi Hood,
Yes thank you, the macro worked fine. Now I can turn them on but how do I turn them off? I tried M9 and it does not work?? Also where can I learn the syntex for the macro language?
Thanks for your help, Boots-2b1
« Reply #5 on: November 04, 2009, 02:20:03 AM »
You will need a macro to turn them off, if you wanted them to all turn off together then you could have one macro which did that but if you want individual control then you would need a macro for each. For example to turn Output 4 off you would have the following in the macro.
DeActivateSignal(OutPut4)
Ray (HimyKabibble) has recently done a pdf with VB commands in it but some of them may only be for the up coming rev of Mach. Other sources are the wiki  and often a good one is just to look at other macros with the editor in Mach.
Offline Boots
  •  17 17
« Reply #6 on: November 04, 2009, 10:36:46 PM »
Hi Hood,
I used the DeActivateSignal (OutPut4) command it works fine. After a little messing around I got all the relays working properly. I wrote a seperate macro for on and off for all 8 relays. I buzzed it out today it worked great.
I did notice in the documentation for the 106 I/O board the the relay numbers are not in order 2.3.4 etc it is 2.3.5. etc I kept trying different pins until I got each relay to work properly. I check the Port Pins Outputs and pin assignments and they were correct. The doc just lists them wrong.
Boots-2b1
« Reply #7 on: November 05, 2009, 01:14:39 AM »
No problem, glad you got it working :)
