Hello Guest it is November 07, 2026, 10:46:14 AM
Author Topic: limit switches  (Read 11350 times)
limit switches
« on: October 28, 2009, 11:26:25 AM »
I have wired alll my l-switches in series, NC, and conected to ground and pin 12 on my board What have I done wrong? I get no indication of the working.
Re: limit switches
« Reply #1 on: October 28, 2009, 12:20:08 PM »
Ste them up as such in ports and pins?
Re: limit switches
« Reply #2 on: October 28, 2009, 12:35:12 PM »
Should they, be set active low, and what do I do with emulated?
Thanks for the help
Re: limit switches
« Reply #3 on: October 28, 2009, 02:12:03 PM »
Probably active High but doesnt really matter if you are not getting anything working. If you had the active state set wrong then all that would happen is you would see the LED on the Diagnostics page go out when you activated the switches and it would then just require you to change the active state to the opposite. The emulated is only for simulating things such as switches and other Inputs via your keyboard, used mainly for testing purposes when you dont have real switches hooked up but you need to test them for simulation.
If you want to attach your xml I can have a look and see if I can find a problem.
