Hello Guest it is October 20, 2026, 08:41:09 PM
Author Topic: Axis Drive Design Helper Spreadsheet  (Read 28259 times)
« on: October 27, 2009, 10:07:34 AM »
Below is a spreadsheet I've created to help with drive design.  It supports both steppers and servos, allowing you to enter component parameters (motor voltage/current/inductance, drive reduction components, screw type, etc.) and it calculates such things as optimum supply voltage for steppers, overall reduction ratio, step size, steps/unit, axis thrust, required step rates, etc.
At this point, I can't guarantee it's 100% complete or correct, but it is to the best of my knowledge.  If you find any problems, or see anything that should be added, please let me know.
Updated spreadsheet 10/27/2009 12:15 PST to correct errors in metric conversion, and thrust calculations.
« Last Edit: October 27, 2009, 02:17:58 PM by HimyKabibble »
Re: Axis Drive Design Helper Spreadsheet
« Reply #1 on: October 27, 2009, 10:15:14 AM »
Hi Ray,
  This is cool !
When I select Cont. Torque I get this pop-up for Inductance.
Is this right ?
Russ
« Reply #2 on: October 27, 2009, 10:48:57 AM »
BTW - The user should ONLY enter values into the green cells.  All others are doing calculations, and should not be modified.
« Reply #3 on: October 27, 2009, 10:54:50 AM »
Hi Ray,
  This is cool !
Is this right ?
Russ
Russ,
Nope, that's a oopsie.  Now fixed.  Just download the file again.
Thanks!
« Reply #4 on: October 27, 2009, 11:17:41 AM »
Nice job Ray,
Should come in handy for a lot of users.
There are programs out there that go into great depth for evaluating a drive system.
But yours is additive to them since you get some basic values for intial motor tuning.
« Reply #5 on: October 27, 2009, 12:50:54 PM »
Ray,
   This certainly will come in handy for many.
I think we need to put it in the Members Docs. when all is done, maybe even make it a "sticky".
It answers many questions that arise when setting up a rig and will be great to direct users to.
Could also be a good idea to inset a link to it in the Mach set-up pdf.
I'm sure it will get many referrals.
NICE work.
Russ
« Reply #6 on: October 27, 2009, 02:19:11 PM »
I've revised the spreadsheet to fix a couple of errors:
Thrust calculations were not correct.
Metric conversions not always correct.
Re-download to get the corrected spreadsheet.
« Reply #7 on: October 27, 2009, 03:12:27 PM »
Hi Ray,
very nice spreadsheet you have made :)
However there seems to be some errors still. Motor power at target feedrate both stepper and servo and thrust at target feedrate for servo. I'm working on correcting the formulas even if I'm not familiar with the new versions of excel.
Edit: This is for the metric version. I havent checked the Inch version.
« Last Edit: October 27, 2009, 03:15:17 PM by SteinarN »
« Reply #8 on: October 27, 2009, 03:17:42 PM »
Hi Ray,
You're right!  I fixed the max calculations, but not the target.  I'll get that fixed shortly.
Thanks!
« Reply #9 on: October 27, 2009, 03:31:26 PM »
B30*B49*B22*6140/B27
This is the formula for the thrust at target feedrate for the stepper at metric mode.
Edit: The 6140 constant is replacing PI and pitch conversion.
More edit: I think this works for both metric and inch: B30*B22*B49*6,14/B29
Yet more edit: It certainly does not work for both!
« Last Edit: October 27, 2009, 04:25:08 PM by SteinarN »
