Hello Guest it is November 19, 2026, 07:41:22 AM
Author Topic: Milling is not keeping sharp angles on corners...  (Read 15650 times)
« on: October 26, 2009, 07:59:45 PM »
If I mill a square for example, some corners are rounded, some are sharp or "pointy".
I added a G64 to the code a while back to stop the pauses on directional changes, would that have something to do with it?
Other than the G64 I have not added anything to the code.
I am using the free Lcam...
Sometimes I want rounded edges, sometimes sharp, how do I have control over what I get?
(I am NOT rounding any corners in CAD)
Rich
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Milling is not keeping sharp angles on corners...
« Reply #1 on: October 26, 2009, 09:28:35 PM »
Hi, Rich
G64 Constant Velocity Mode will give you this problem, Use G61 Exact Stop Mode when you want sharp corners.
Chip
« Reply #2 on: October 26, 2009, 09:43:56 PM »
Thanks Chip.
Will a G61 ONLY stop on sharp corners, or will it "stutter" on arcs too? (which was why I used the G64)
Thanks.
Offline Chip
  •  2,055 2,055
« Reply #3 on: October 26, 2009, 10:20:57 PM »
Hi, Rich
You'll probably find that your Arc's are really short line segment's, The only way to deal with it is to find a cad program that generates the arc's as curves so you'll get G02 and G03's, This has always been an Issue, It's been discussed allot and at the moment I don't have any good recommendation's for a cad program.
Chip
« Reply #4 on: October 26, 2009, 10:40:11 PM »
Rich, you may want to look at Autosketch. It draws arcs.
« Reply #5 on: October 27, 2009, 06:24:02 PM »
I guess G64 and G61 together would just confuse Mach3 eh? LOL
Thanks for the info.
Hey Brett,
How is Autosketch in general?
$250 is a lot just to get true arc's, but my CAD is a little "buggy" so if it's good all round I might consider it...I'll have to see if I can get a demo....
Thanks all :)
« Reply #6 on: October 27, 2009, 07:11:07 PM »
Try using CV mode and in General Config, set CV for 89° or more.
« Reply #7 on: October 27, 2009, 07:26:52 PM »
Autosketch is pretty good and fast for drawing DXFs. I thought it was $130..........
« Reply #8 on: October 27, 2009, 07:33:30 PM »
I'll look a little harder, the one I found was $250, $130 sounds pretty sweet tho :)
